check for primary 12 V battery in rear hatch, am sure that battery need replacement. replace with same voltage / rating battery any brand
without allowing any loser doing any non-sense 1st change that 12 V battery. drive around, n then reset the ECU by removing battery negative from battery terminal for 10 minutes.
reconnect the negative terminal and see if CEL ( check engine ) lit up again.
