legally no one can use the dexron brand name anymore as GM has lifted the licensing, so you will find names as DII, D2D, D3, D3H.
The dexron 2 is a very old specification hence is very commonly found now, it is also backwards compatible with even Dexron 6 ATF, but Dex 6 is low viscosity ATF, it might hurt some cases.
