So sorry for your loss.
Looks like you have to replace the bonnet, fender, headlight, side-view mirror and the windscreeen. Replacement parts are easily available in Karachi, from OEM Japanese parts to Chinese replicas.
Good luck with the repairs.
Toyota belta 1000cc 2012 want to change its gear oil plz can any one tell me ka kitna gear oil dalta ha?
[QUOTE=Bindas353;4957582]Toyota belta 1000cc 2012 want to change its gear oil plz can any one tell me ka kitna gear oil dalta ha?[/QUOTE You have to change CVT oil after every 40000 kms, get its quality checked by local toyota dealer now to know if it has to be changed.
Dear Members...
Bought Toyota Belta 1.0 Yesterday.... Can you pl suggest what maintenance should I do? Like Which Engine Oil is recommended for Belta, Also transmission Oil, Coolant or any thing else needed to be done after purchase.
Malik Qasim
Dear SirPlease give me a quote for TOYOTA BELTA BODY PARTS:- BUMPER - TAIL LAMPS SET- FOG LIGHTS SET
CHASSIS NO:SCP92 - 1002540ENG: 2SZ - FEMODEL: 2005
RegardsLovings
replace transmission oil (CVT) only buy original Toyota CVT transmission oil from Toyota.. & change after every 40k-50k.. costs around 4k
Service your Brakes.. change them if requiredcheck plugs.. replace with iridium if requireduse any decent oil.. if the engine is in good condition.. if engine is old.. get any thick oil 20w-50 etc)always try to get Hi-Octane as far as its cheap..or atleast once a month. enjoy the ride
replace transmission oil (CVT) only buy original Toyota CVT transmission oil from Toyota.. & change after every 40k-50k.. costs around 4kAround 4 liter dalta hai.. the mechanic will know.. but change it asap
ideal belta tire size185/60/R15im using it myself & have faced no such issues
Read the whole thread. Its got all the info
https://www.pakwheels.com/forums/showthread.php?t=168298
Thanx a lot... (Y)
185/60/R15 is ideal for the 1.3L (1300cc) models only
165/70/R14 is the ideal size for the 1.0L (1000cc) models
175/65/R14 for the 1.0 L (1000cc) models with alloy wheels
Recently I have been hearing some unpleasent noises, most probably the bearings.... Not sure yet if they are front or back. Has somebody else replaced the bearings? if yes what is the price? and which ones are best?
Need answers of 2 queries!1)Is it safe practice to disconnect battery terminals in Belta while you are away and not driving car for some period?2)Where can I buy in Karachi Toyota Lifelong coolant and how much is its price?
Nobody with any answers?
Although, I have asked and a single bearing is about 3K...
I am not sure from where this sound is coming, the sound is like that of a drive on small bumpy road, even if the road is crystal clear...
Thankyou
Salam
For past few weeks belta's speedometer panel lights are not working. That includes parking lights too. While climate control lights are ok. Low beam and hight beam both work. Checked all the fuses at passenger side and all are good.
Any suggestions?
Check wiring under the steering. Else an ODBII scanner can diagnose the problem. Take it to any technician who has it (preferably Lexus 2nd Gen because it has codes of all Belta variants).
Does it come while slowly accelerating and at times when you keep your foot on pedal for a constant speed?
Thanks for the reply..It's constant whether I am on slow or high speed... Have figured it out, it's bearing of left side, it's a sound like i am driving on a bumpy road....
