Now I am facing another issue. Initially the issue was the RPM was not stable like when I put the car on D or R the engine was turning off, it's like the car was missing. After inspecting twice I came to know the temperature sensor was causing trouble it was not giving the right temperature to EDU. So, I ended up the changing the temperature sensor.
Now the problem is when the car is cold and I start it after 7 8 hours the RPM is not stable until the engine warms up. It takes around 4 5 minutes for the car to become stable.
Note: I have cleaned the catalytic converter, checked the air sensor, vtech, changed the injectors, coils are fine. So I think I have checked almost everything.
Any suggestions?
