jumbolon was the addition?
did it worked? means reduced the heat?
Just placed the orignal namda above Jumbolon..
3 layers sound deadening for firewall
i have a plan to install a sound deadner also! any idea?
Yup there is a significant difference for heat.No idea for sound deadning sheets...
i watched a video on youtube, a man was using a sheet, color was silver with the built in sticker and he was calling it sound deadner, he was using it in the front door to reduce the vibration of the door due to front speaker
Yup those sheets are available with some car accessories shop's but they are a bit expensive... Like the cheapest one i know was for 13k RS for firewall and floor.. That was 2 layer's one was some foamy type material of 2mm thickness the second layer was of heavy rubber that was 3mm thickness..
13 thousand????
i want just for the firewall
Yup 13 thousand..If you just want heat insulation then even Jumbolon will do fine. But for sound deadning you will have to look around in markets for that stuff.. Every shop will offer you something different at different price survey the market and then decide..
thankyou for helping and sharing
assalam! can we change all the four floor panels in the 1986 corolla? mine are rusted, already repaired in a weired manner, i want to completely change them. help!
opened the whole interior
bought a kabali cooloing box for Rs 8000.
The previous owner of the car has made a kabaarh of it.
Yup complete floor panels can be replaced. Just find some good denter for that work.
taiwani and local printed sheets are available in market.
any idea regarding prices of local as well as taiwani floor panels?
does changing the floor panels make the car "cut car" means will it create any problem regarding law?
