What about 185/55/15? Because only tires won’t cost me much but both tire and rim change will cost me more. Ideally if i had budget i would had gone for 185/65/14. Bigger than 14 for these cars ain’t good.
185/55 comes in low profile range. I always say that rim are not the problem it's the tyre profile. Total diameter of 185/60R15 will be about same as 185/65R14.
I will most probably go for 185/55/15
do share price, brand and road grip of 185/55/15.i am running on factory specs 13" wheels in ee90 and lacks road grip
185/55R15 jerk will be same as 195/50R15. Between Diameter of 185/55 is small....still your money you choice.
I asked from some shops they said 195/55/15 is available mostly. 185/55/15 is not available in new but used tires.
Dunlop made in thailand for 6000 195/55/15. 185/55/15 not available atm in pindi.
If you have budget then go for 185/65/14 with good alloy rims.
What jerk bro? Bro mostly 195/55/15 is available but 185/55/15 is not easily available.
Yep this profile is used most widely. Even you can get all 4 (used loot) tyres for 3k
195/55/15 for 3k? Here they are minimum 10K for used ones. Mostly Dunlops and Yokohama's. 195/55/15 wont rub the body? I want the size which doesn’t rubs the body in 15”
Mean impact. It will rub if your car is dropped. Or at stock height. 185/65R15 is also easily available. Those tyres are used came in containers.
Bro if lowered what size will be best and which doesn’t rubs.
Bro 65 is bit bigger profile i want to go for 55 profile. My preference is 185/55/15 but here 195/55/15 is available. 185/60/15 is available but not 185/55/15
Bhai 185 ka sath 55 profile choti hai wheels awkward lagaien gy itni lifted gari ma.185 hi rub nae kra ga. 185/60 dekh lo apMy friend recently install 185/65R15 wheels in ep70. He is not facing much rubbing issue. I will upload some pics tomorrow.
14 doesnt look appealing as compared to 15
In 15 then go for low profile like 185/55/15
If I was in your place I would go for 185/60r15.
i have also corolla 1986 am i m from sahiwali have 1 problem could not find headlights if anyone have solution plz contact me my no is 03334800043
one of the biggest issue bro
