like i said before i do have altis 2006 but its auto, i have also driven a 2007 manual altis, rpm should not be this high do check if your clutch is okay and engaging properly, your clutch wire may not have enough tension and your clutch is only partially engaged causing this high rpm, even GLi 5spd manual rpm at 120 is 3800rpm, manual altis should have no more than 3000 rpm
