Asalam o Alikum members,I have corolla 2007 83k driven throughoutly petrol driven no cng installed.It was doing good till 70k then i went to toyota 3s to replace its old parts belts etc all in 80k checkup Well from that day im feeling high engine noise after 2k rpm and that cheap noise which comes from old cars! My car has done 8k millege after 80k checkupSo what you guys suggest what should be the problem? Im using shell oil 10w 40 is it right oil to use?
which type of noise???? what part did you changed???
Bro i dont know exatcly but they changed all belts fluids disks etc etc which have to be changed in every 80k checkup And they issued bill of 40kWith one dent fixing and a new back light
@capsat @xulfiqar
Maybe the belt that they put on was not tensioned properly... Get the belt re-tensioned....
Cheers...
maybe it is the tappets. they can be adjusted, but not like you do in a mehran , nor by kharadiya (mechanic will suggest kharadiya, but it isn't a good fix)
look like toyota hired some mechanic form paksuzuki 3s
Thanks allBtw toyota suggests 10w 30 engine oil So which is best oil as per specifications
problem solved???????
