150000 is mid life of a X-NZ-FE series engines.
hose pipe damage means engine overheated and gaskit needed replacment.
visit a shop which can perform compression test, if dry & wet readings are over & above 160 psi get the head job done. mechanic can check for head warp causing piston noise, if it is out of specs source only head.
you have choice to simply buy a complete head from scrap yard rebuilt it by replacing oem new gaskit valves & lifters ( dabbo ). engine will be fresh new . Use only 5w-30 or 10W-30 engine oil grade and engine will again pull over 200,000 kms more.
