@Xulfiqar
I plugged the scan tool today once the car was warm and Fuel management system was in closed loop, O2 sensor properly heated up. No DTC, No Monitors showing any failure. Only single bank (bank 1) readings are there, because there are no multiple bank sensors in place for this model.
Here are the results for O2, STFT and LTFT.
RPM: around 800 with AC off at idle with no foot on accelerator
O2 Sensor Voltage: Oscillates between 0.08 and 0.8 V
Short Term Fuel Trim: Oscillates between -3 and +2 approx
Long Term Fuel Trim: -3.2
Upon shifting into 1st and depressing clutch slowly without any pressure on accelerator, car shakes and start to move and Short Term Fuel Trim dips to approx -4 and sometimes -5
RPM: around 2500 with AC off at idle with slight foot on accelerator pedal.
Long Term Fuel Trim: +2.2 approx.
Although Fuel trims are not off the charts at idle RPM and at 2500, but looking at LTFT value of -3.2 and dip in STFT on depressing the clutch, can we say that ECU is not getting the required Air it should be and we have somewhat rich mixture as LTFT suggests. Is it possible that IACV is somewhat choked.
Please share your thoughts.
Regards
