AoA, i need technical help regarding solving some issues i have with my ride.
i recently purchased a used 2015 model automatic 1.3 Gli, around 87k driven.
When i purchased the ride, i immediately got all oils and filters changed ,there was an issue with vibrations on breaking, got brake service and after market non geniune brake pads installed, which solved the brake vibrations but are now causing tick tick noise on breaking.
Another issue that i recently noticed was that car used to vibrate between 40-60kms and also above 100kms.
Tryes were wore out so got new tyres installed and after wheel balancing and alignment from toyota dealership that vibration between 40-60km speed is reduced but it is still there
,it happens sometimes and being a driver i can feel it. Passengers are usually unaware of it.
I found toyota dealership people to be not much useful and knoweldgeable and they were just making guess and are not sure of the reason for this, on road test, the driver was not much appreciating those vibrations even though i can clearly feel them.
And to be honest, drive is still not buttery smooth after changing tyres, it seems a bit rough to me.
Engine is fine, rpm doesn't drop. No codes on computer scan etc.
Toyota people identified following issues with car.
1- bad Rear engine mount( estimate they are qouting for replacemnt is 15k for mount and 1700 for labor)
2-Rims are unbalanced
3-There is click /mild play in steering and they are saying k kangi ka kam hoga, costing 18k total expanse for this.
4-Idle vibrations which they say are due to bad engine mount
Now I just spent hefty amount on car, and then bought new tyres too, i am still ready to spend some more amount if my problems are solved but i am looking for someone to actually guide me and diagnose my exact issue.
Is it engine mount, is it crocked alloy rims, is it kangi?
Please someone who is well verse with Toyotas , please help.I went to Toyota Township motors and to be honest they are not that helpful and dont seem any different than local workshops.
I just shifted from Honda and Honda dealerships were way more trained and helpful then toyota.
Can anyone recommend best toyota dealership in Lahore?
