I own a toyota Gli 2018, which has only done 50k on the odo until now. Recently i have been experiencing a reduction in the cooling from the A/C and occasionally the A/C starts blowing hot air and basically trips abnormally. I have read many thread and tried my best to research about this problem. The dilemma i am facing is that, this is a common problem in cars with variable displacement compressors and most threads suggest that the solenoid valve needs replacing but when i visited the local car mechanics , they suggested that the only solution is to replace the compressor with an old clutch driven fixed compressor or replace it with a new one which costs a fortune. Can anyone please help me out or give me some sound advice regarding this problem. Thank you
@Xulfiqar Bhai, it would be very helpful if you give your insight on this issue. Thank you.
