I have a corolla GLI (Pak assembled) 99 AT. It does about 120 KM on 55 pounds cylinder in city. is it OK? But the problem is that on patrol it does only 10 KM/L on highway. A mechanic asked me to replace the injectors with that of VITZ. but one my friends is of the opinion that it will ultimately weaken the engine.
Any Expert Opinion?
Thanks
please share more details of maintenance, when was the last time auto transmission fluid & transmission filter changed, fuel & air filter change history, plus what is wheel & tyre size you are using. last but not least THE odo meter reading,
ho sakta hai ke fuel pump kamzoor ho! besides that share the details that capsat has asked for
What else do you want from 1.6L engine? i believe 10Kmp/l is justified anything greater then or equal to 10 is good and cng mileage is also good. Your Mechanic is Dumbass how can he use vitz injectors which i believe is either 1.3L or 1.0L in a 1.6L car? Get your car completely tuned and see the difference not from roadside ustads.
@capsat @aamirq It has done 230000 KMs. I using it since Jan 2012 and generally changes oil (10W/40)along with oil filter on 3500 kms. I have never changed transmission oil. Air filter is changed as and when recommended by service boy. Tyre size is 185/70-R14
at 1st available time slot please change the auto transmission fluid & filter BOTH. USE Toyota transmission fluid and Genuine Filter this prescription will cost you under Rs. 10,000 but will improve upon the vehicle handling & fuel economy. for your own safety as a vehicle user please READ THIS
It gives BAD GATEWAY error.What is your opinion about injector change. should go for it. I have used ZIC ATF when AT fluid was deficient. is it ok. One of the mechanics here in Peshawar told me that AT filter is not available in Pakistan. Do you know where can I get it?
click here-goto toyota shop and check estimate & timing required for atf fluid & atf filter change, or check from member Asad Sethi / BK they are from your town and know thing quiet better.
A mechanic also suggested to my Father to install vitz injector on his 1999 5AFE swapped Indus Corolla manual transmission for better fuel economy.Now the car makes an exploding sound on CNG.I feel bad for the car.
