Forgot about android update because newer versions are also need hardware supports, you can try search may found custom released by developers, to update if you found is bit tricky method by usb plugin flash, command port mode , in my suggestion whatever app you want to install , install by apk file transfer into your device , it’s also not for sure all apk get installed in your old android os due to incompatibility
