For 1.6 cc max r15, if 1.3cc max r14 the stock size.
@KamranAslamYou got front disc pad China copy?.. How long will it last and what is current price difference between China and oem front disc pads rates...I got my car front disc pads changed oem...5 years ago.. rate was 5000 and till now I travelled 50k and still 6mm thickness remaining... So I live in hilly area where brakes are used more frequently... So always opted for Oem brakes pads.. don't know current price
@nawan885: there is no replacement to OEM ones, these costed 2600, stock ones are around 13k to 14k both front and back. These installed ones I guess will run 2000km.
*20,000kms
@KamranAslamGreat bhai.. I think current price of front disc pad pair is 8 -9k.. I guess from pvt dealer... but u are trouble free for a long period. I will recommend for those who are in hilly areas or travel on long route and motorway
I always used MK brand Pads in my Dumba, works perfectly and changed two times in 4-5 years period, Currently in my 2013 installed same MK Pads, let's see how much time they lasts in this Car , my monthly car running is around 7.5-9K KMs
^^ I was very found of MK during my cultus days. But after an experience with counterfeit I backed off.
6500 for front OEM pads. where are you from ?
@def3nderThanks from AJK
Today I done some AC service at home, changed cabin air filter and serviced AC condenser with tap water
feel any difference in airflow after filter change? u cud have sprayed ur fav perfume on the new filter n let it soak well before putting back
Yes airflow is now feeling better or may be its placebo effect but whatever the case it was due.
Good idea pehlay nahi aaya mind may
Sir yeh kitna ka mila?
Rs.800/- with delivery from Daraz. Direct shop say shaid 150~200 sasta mil jaey
Does anyone can help me to arrange this sun visor grip in Karachi since mine right hand side got loose and left hand side's clips are broken.
Same is story of passenger side sunvisor with... one clip broken but I m living with it
My driver side clip got lose while passenger side clips is damage!
I found a active trunk bulb holder in the diggi, decided to place a bulb to it from my old bulb collection, a number plate bulb attached to it. And the trunk lock comes with a active switch too, I was surprise to see this in Xli. Me very happy to my DiY.
Was unable to clip it, currently placed via transparent scotch tape at the edges of the light.
