Salam All,
After the mount replacement and throttle body cleaning, im still facing an issue related to idle rpm. The cold start of the car is fine, as it was before. The choke is working as it was before. When the car is heated up the rpm is not as it should be. When i press the paddle at the signal, the rpm drops to 500 and then comes to 800 and stays there. At 800 rpm, I can feel the vibration. I have adjusted it thrice with the choke and with the throttle body screw itself but it stays there as i do not allow the mechanic to fiddle that screw much. Interestingly the rpms are absolutely fine with the headlights on. When i come to stand still, the rpms comes to 800 and then rest at 900 every time with the headlights on but without the headlights it comes to 700-800 after touching 500...What could be the issue and how to resolve it? If I raise the rpm from the choke, it will also raise it with the headlights on. With the headlights on, it is maintaining at 900 and if i increase it it will rest at 1000rpm which is high.
