How much kms were on odo?
Near 200k km but its 1nzfe.
My car has stock engine 3zz fe and around 170K odo. Have you overhauled the engine?
As i use totally on cng which burnt valves.
It was opened first time, not even for gaskit.
Does your car have 1nzfe stock? what model was it?
At least person should buy compression tester it tell all story of engine. It cost 3500rs from daraz. N easy to use
Swapped before i bought
Yes we should not rely on mechanics for every thing
Even it tells wheather valves are leak or pisyon
Yes I have seen videos on YouTube
Btw gari crankshaft sensor ke waja say bhi back fire krti ha.
@hasankhurshid29 call 0300 9232821 Jameel Autos visit themtell them the problems and ask for diagnostics and solution. They recently re-worked over a 2005 Diesel corolla which is now at body shop.
pay attention to suggestions from @Xulfiqar
Thanks
please somebody explain me how fuel trims work in this model without an O² oxygen sensor.How ECU moniter the exhaust gases?
there is fuel trim pot to set air to fuel ratio....but i recommend donot messs with it..
Good to See @capsat and @Xulfiqar aboard.
@Xulfiqar: I recently bought a 2007 Xli 128K on the odo. Going Strong till now. @AsifAslam took it to high way trips for Bhawalpur and surrounding no complains.
is the picture from st.dominic cemetry, the over pass reclaimed some land from it ? correct me please
Correct, was at a visit to Dada jee Grave. Took a clean water gallons along.
Supreme ONE Bless the departed ..
