If you want to remove the CAT then you have two choices:
A. Have the mechanic break the internal jaali by either breaking it with a long screwdriver and hammer or cutting the catalytic converter dholki by the side and removing the whole honeycomb.
In this case you have to raise the O2 sensor by around 2 inches so that it will detect less exhaust and not give you the checklight
B. Total removal of the CAT silencer and fitting a new normal silencer in its place.
In this situation you will have to make place / hole in it to fit in the O2 sensor and also raise it around 2 inches
