txn=transmission=gear system of car
i think ur AT (auto ttxn) is working fine.
as the car starts in 1st gear, then u feel 3 shifts ( thats ur 4 gears ), and after that u feel that car has become smooth, thats TC lock up happening, means the gear is at its final ratio and car is cruising.
u can ift ur foot from gas pedal to let it shift.
so when u shift the car in D, it starts rolling without even pressing the gas pedal?
yes ur car has a Cat Conv and o2 sensor, only this particular model havin 1zzfe engine got a cat conv, other models like Xls/Gli/Se saloon etc dont have it.
can u reach 120/130 relatively easily, without feeling that engine is struggling?
u can ask the previous owner about it, its a bit important, u need to know which oil has been used mostly. BTW it takes 4.250 liters of engine oil.
Also check the previous owner about Auto Txn oil change, it needs to be changed every 40km, u can check it by inspecting the dip stick, its a yellow stick in the right side of engine bay.
if u can feeling burning odour and oil is very dark in color, then better change it,
PCV is postive crank pressure valvle, its under the engine cover on the upper right side of engine, get clogged up if not cleaned ever, need to spray carb cleaner after opening it and shake it, if it clicks then working fine, else repeat.
