Eid Mubarak to All Dumba Club Members@KamranAslam @xenerking @def3nder
Thanks buddy..Eid Mubarak to u aswell
Also Eid Mubarak to your Dumba from my Dumba
EID MUBARAK everyOne !!
I guess mujhe Pakwheels walo ney demote kar dia hai
Hello everyone. Weather is on peak nowadays. How is AC performing ?
Khair Mubarak
A.C. is good, but the scorching sun does not let go until the window shades are there.
Filled the tank to top with 30ltrs after 255.5 kms calculation came to 8.5kms/ ltr with AC again few times parked with AC for 30, 40mins.
I am sure some thing is wrong. Which spark plugs you are using and what about fuel filter How's the pickup & start up?
Spark plugs don't remember, will see in the morning. Will have a look at the fuel filter too. Pick up seems fine. Will take it for a check up in the morning, do suggest me the areas to work on. Thank you.
Fuel filter is not the issue. First clean MAF sensor. Make sure air filter is not choked or dirty. If nothing helps then go for ultrasonic injector cleaning.
how was fuel average in winters? slightly better or much better...
if fuel average was goo din winters then i think AC might be taking little bit more load on engine due to overcharging or some other reason, do check that as well
@KamranAslam if you think dumba is not fair to you Its the normal average of my Dumboo
7.4kms / ltr. For a 1.6cc automatic, normally its between 8 to 9 for in city, I will say not that bad.
But mine being a 1.3 Manuel should be little better, how ever I went to my mechanic today noon got the MAF sensor cleaned, replaced plugs. AC filter replaced and engine air filter cleaned.
Ring rubber was missing on the MAF sensor placed a new one.
Denso plugs rupees 250 each, AC filter 250.
Previous plugs seemed all good, but the mechanic advised to replace them with new. Old ones are still with me.
