i think one plug will cost around 1400-1600...set of four shud b around 5k
by drag..i meant initial pulling force required to move the car from standstill....during city drive this happens everytime u move ur foot from clutch
You have to live with it and enjoy its positive sides specially drive and performance.
So you also use iridium spark plugs?? What differences you felt???
Yes I also called him he told me same amount now one more thing I want to confirm if an engine consumes oil then will it damage the spark plugs also????
Yes in worn engine where plug seals are weak, spark plugs get affected.
@kamran aslamIf you opt for Copper plugs then 4 Tip plugs by Bosch are better choice.
In Irdium plugs, NGK is also good option with Counterfeit check code
I dont know exactly which seals are worn out but my car consumes oil for whatever reason
Im getting 5km/l 1nz Auto but i drive on Cng.
Iridium plugs does not add extra horse power or improve fuel average. They last longer than copper tip. Thats only difference. While BOSCH 2 tip or 4 tip is just scam.
Corolla fuel filter does not require replacement unless you are facing power loss, long starting, engine stalling , missing at high rpm.It can be checked by placing a pressure gauge on fuel line. It will clear two things. If pressure is dropping after switching off engine then one or more injectors might be leaking/faulty.If pressure is between 45-55 psi then no need to change anything.P.S there is no OEM filter available in market. It comes with complete plastic housing. Only cheap chinese/taiwan are available.
wah even exceeding manufacturer expectations...
Bhai kon c performance? 60 se uper chali jae tou breaks ka dar.. is lia chup ka k point a to b ka distance cover karo bs
Never had cng in my dumba Alhumdulillah. Idk but i dont like cng. it gives a better mileage. but still.
this guy was running dumba with hi beam no good thing.
In that case you should try Suzuki Alto and then tell me its just point A to B case or anything else
@xenerking bhai aap bhee koi video share karo apnay kee
i have bro. and tbh i believe myself to have more control on mehran breaks than dumba.
Na kro yr Mehran k stock brakes tu non booster hain
back seat par filthy balti rakh kar??
