Salam guys,
I have a problem with my radiator and condenser fan operation. I recently redone the wiring myself using Toyota's wiring diagram. I have the following scenario
• Ignition On
• A/C Off
• High Coolant Temperature
• Normal A/C Pressure
A/C Condenser fan not running. Radiator Fan runs as high (full) speed
In my case, both fans run parallel at full speed, which is not what I want. Ideally only radiator fans should run. I have a snapshot of Toyota wiring diagram for radiator and air con operation. The diagram is confusing/misleading OR I can't understand it properly. I might be missing something, that's why I am asking you. Here is a snapshot of wiring diagram.
@SER_GTR @Xulfiqar
