Not always... It happens only if it drops below 100, it then creates starting troubles.
But if compression is in 120-130 range it gives bad economy of 5-6kmpl... So whenever someone complains about that low economy. Bad compression & multiple cylinder misfire caused by bad coils, bad short plugs, bad blown injectors is the cause...
If there's no misfire and still bad economy then 100% surety that its bad compression. Cuz any sensor, thick oil grade or any other thing never drops eco too low.
It only drops to 2-4kmpl drop at most.
