Tenth (S150 Model: 1995-1999)
The 150-series Crown were built as Sedan and Hardtop (frameless door window) only. This was the first Crown to not use separate chassis construction. The Wagon retained the old and unispired Japanese Lexus(130 series) model until 1999. Trim levels for Hardtop are Royal Extra, Royal Saloon, Royal Saloon G, and the sporty Royal Touring. 4WD is offered for Royal Extra and Royal Saloon. Engine is either 2.0, 2.5, 3.0 liter 6 cylinder, or 4.0 liter V8.
Eleventh (S170 Model: 1999 to 2003)
Crown Royal JZS175
Crown Royal JZS175
The 170-series features shorter front overhang therefore maximizes interior and trunk space. There are three different 170-series 4 door Saloon, Royal, Majesta, and Athlete. The 4 door Hardtop was discontinued. The 170-series Estate was the first new Crown Wagon after the 130-series. Engine is either 2.0, 2.5, 3.0, or 4.0 liter. The Athlete V has 2.5 liter 1JZ-GTE turbo. The Royal was also offered with 3.0 liter 2JZ-FSE Mild Hybrid.
Twelfth (S180 Model: 2003 to present)
Crown Royal S180
Crown Royal S180
Based on the Zero Crown concept car. Engine is changed to a V6 for the new Royal and Athlete models, and the Majesta uses the V8 only, now in 4.3 litre form with 4WD optional. The 170 series Crown Estate continues using the inline 6 cylinder engines.
[edit] Engine data for the Crown S180
* 2GR-FSE
o V6 DOHC 24 Valve D-4S 3456 cm? 232 kW (315 PS) at 6400 rpm, 377 N?m (38.4 kgf?m, 278 ft?lbf) at 4800 rpm
* 3GR-FSE
o V6 DOHC 24 Valve D-4 2994 cm? 188 kW (256 PS) at 6200 rpm, 314 N?m (32.0 kgf?m, 232 ft?lbf) at 3600 rpm
* 4GR-FSE
o V6 DOHC 24 Valve D-4 2499 cm? 158 kW (215 PS) at 6400 rpm, 260 N?m (26.5 kgf?m, 192 ft?lbf) at 3800 rpm
Models in the Crown lineup
* Crown Comfort
* Crown Sedan
* Crown Majesta
* Crown Royal
* Crown Estate
* Crown Athlete
Twelfth (S180 Model: 2003 to 2008)
Main article: Toyota Crown S180
Toyota Crown S180
2003 Toyota Crown
Manufacturer Toyota
Production Toyota City, Nagoya
Class Mid-size car, wagon
Body style(s) Sedan
Wagon
Platform S-series
Engine(s) 2.5L 4GR-FSE V6
3.0L 3GR-FSE V6
3.5L 2GR-FSE V6
4.3L 2UZ-FE V8
Transmission(s) 6 speed automatic
Wheelbase 2850 mm
Length 4840 mm
Width 1780 mm
Height 1470 mm
Related Toyota Aristo
The S180 model of the Crown was based on the Zero Crown concept car. The engine was changed to a V6 for the new Royal and Athlete models, while the Majesta used the V8 only, now in 4.3 litre form with 4WD optional. The new engines gave more performance while also giving better fuel economy.[2]
Compared with the previous model, this model was increased by 70 mm in the wheelbase and 15 mm in body width. These changes gave it the largest interior size among its contemporaries, more than the Mercedes-Benz E-Class or BMW 5-series.[2]
The S170 series Crown Estate was continued alongside the S180 sedans. It continued using the older inline 6-cylinder engines.
