Oil it's indicates the leak. If the parts are not dirty already. If the wire is not broken. It just need minor adjustment.
Can gearoil leak from passenger side or driver side?
Sorry didn't get you. Gear oil from transmission?
Yes gear oil from transmission
If you are referring passenger and driver sides to transmission sides then yes it can leak from either of the side.
How much grease should be used in inner cv joint.I poured 90 grams in outer and inner one.And used cv joint grease.
Not sure about amount. Don't have to fill it up all the way. Just need to cover the moving parts. Your good to go.
Yes bro,I only covered the moving parts
That should be enough .
No never
Assalamualaikum bro how r u?It's been two weeks now that gear shifting problem is gone by itself.Gears are smooth now.Also after replacement of axle boots previous axle noise is also gone now.
Wailaikum Assalam ALLAH ka shukr how are you?Noise of axles would be going after you lubricated them and installed new boots.Have lubricated shifting cables?
Alhamdulilah.I didn't lubricate anything.It went away by itself.btw how much should front brake rotors cost
Hope it doesn't come back again. Between did you changed gear oil?Brand new or kabli? Brand new cost alot. Kabli would be about 1-2k.MASHALLAH your need a drop🤭
I changed the gear oil when I was changing clutch plate.I installed kabli today costed me 3,500 in good condition.I guess this is stock height.Drop would look cool but speed brakers and rough roads are a big issue here.
I think gear oil changed helped. No actually e100 floor is pretty high. Moderate drop wouldn't hurt.
Ok bro.
