Most probably distributor seal.Look under the distributor.
It's wet under the distributor
Distributor it is then.
My rear taillight brake light don't work when parking light gets on but works when parking is off.Strange.
Check the grounds.
Where will be it's ground located? The black wire of connector?
I think was on the trunk latch.
Assalamualaikum how r u?Does this car have rear wheel bearings also or only front wheel bearings?
Wailaikum AssalamALLAH ka shukr, how are you?Yes they have bearings as well and also new available.
AlhamdulilahThanks for information.
And is timing seal and crank seal same thing in 5afe?
Yes actually. Although correct word is oil seal.
Ok thanks
Assalamualaikum how r u bro?What r ur suggestions for replacement brake shoes fot rear drums?A person told me to get used kabuli brake shoes as they r original?
Wailaikum AssalamALLAH ka shukrHow are you?Nae. Buy brand new ones.
I'm fineOk thanksAnd are glass headlights superior to plastic ones
I observe them to have more life. Doesn't turn yellowish by time.
What about their light on the road compared to plastic ones?And which ones will be more durable
Mirror. About light throw both are same.
Great
