That's true.Availability is the issue.Does microfiber cloth has any benefit for waxing of car.Or is it ok just to use normal cloth.
microfiber cloth is recommended.
What does goday of car mean in English?
And is axle boot and shock dust cover available new or kabuli is only option?
Both are new available in marketCv joints are called as goday.
Is there any specific brand ones I should get.Actually my left boot is ripped which will damage axles.Thanks for helping.Also my fuel gauge goes up and down.
Get oem ones. While turning? Or with electronic load.No need.
Any idea about cost?While turning.
Your is converted to efi? Inner got damaged or outer? Boot will cost like 300-400 i think.
Mine is converted from dieselOut is damaged
It needs machine shop work. Means have to take it to kharadiya. Petrol and diesel have different fuel gauges. Be sure voltages are not dropping and that there's baffle in side the tank. If you drive it with low fuel usually then it's normal.
Will it be hard to fix it?And diesels don't have baffles in the tank?
No easy jobNope.
Ok.Glad to hear.What do we call baffles in local mechanic language.Also how can we wire fuel pump through relay.Can we trust local electricians for this.Sorry for asking too much questions.
Btw idle up price was 1200 rupees.Will be helpful for someone wanting to install in their car.
Wese @humayun.chughtai.7 bhai does ur fuel gauge work properly as ur car is convert from carburetor to efi?
Yes ... a good electrician can wire up the fuel pump properly.
Yes, fuel guage in my car works perfectly alongwith reserve light.
Any changes u did to the fuel tank?
Glad to hear.
