ultrasonic baths cannot be done on regular basis as it actually does erode part of the injector pintle assembly, This is the reason that most car manufacturers recommend a "dialing in" of the fuel tables after this.
If you dont do the dial - then your long term trim will always be somewhere in the below negative 5 or 7% range no matter what you do to the system.
This liquid is nothing more than any other OTC injector cleaner product - Toyota do not recommend this on a regular basis specially on dead head (returnless) fuel system cars as the fuel passing through to injectors goes through the filter once only - this keeps the filter pretty clean and thats why they can advertise it as replace every 100,000 kms or something.
btw - when you dunk this in fuel - it makes very little difference, might as well assume its in, to get real results from this you need the pressure canister.
