apparently it seems TPS is at fault, if altis doesnt have TPS then it must be having IACV, did u recently get any tuning done or removed battery lead or the problem started after a car wash
the other area might be a vacuum leak
plugs or coil shouldnt raise rpm
CVT down shifting is possible if fluid pressure is varying or oil is thick, still not a likely symptom
