Try again with usama he is a talented and has a good approach on diagnostics in lahore.
Possible area of trouble can be TCC solenoid,
Wiring loom, or the exu itself so start with the TCC solenoid and its wiring then move slowly toward the ecu replacement.
Most of the cases has to be seem with wiring damage inside the transmission
This k410 is naughty for its convertor solenoid problem. If the problem still persist after the above procedure then be ready to swap the whole transmission.
