LandCruiser 200 GXL is accessorised with 18" x 8" Alloy Wheels, Reverse ParkAssist, Towing Kit (On Road), Trailer Wiring Harness, Aero Roof Rack (2 Bar Set) and Atlantis 200 Pod
Alloy Bull Bar
Go cruising without the bruising. Durably engineered from rolled alloy extrusions and pressed lower panels, this highly polished and superbly crafted bull bar integrates with the LandCruiser 200. It's been designed using the latest 3D modelling technology for unrivalled performance, style and airbag compatibility; plus rough-road-evaluation tested by Toyota for further assurance. Factory fitted fog lights are accommodated (if equipped), and there are dedicated installation points for Toyota Genuine driving lights (excluding larger RALLYE FF 4000)
For that extra room on top. The Aero Roof Rack has an extruded aluminium cross bar for strength, and is black anodised for corrosion resistance. It also features rubber cushioning strips on the cross bar and tamper-resistant fasteners for theft deterrence. Rated to 100kg (total) capacity evenly distributed over two bars, and compatible with LandCruiser 200 Roof Rack accessories (excluding Alloy Roof Tray). Aero style third bar also available increasing capacity to 150kg.
Atlantis Roof Pod (Available in 200, 600)
(200 shown above) The Atlantis Roof Pod range is the premium style solution in adding extra storage space to your LandCruiser to keep up with your family's adventures. The Atlantis 200 and 600 Roof Pod's are glossy silver in finish, built to last with both UV and impact protection, and are aerodynamically designed for reduced wind resistance. They're the perfect addition to your trip up the coast, the country or as an everyday solution to help carry around whatever it is that's important to you. Power grip attachment solution is pre-mounted in the box, allowing you to tighten its grip with a single hand. The system also centres itself over the roof bar providing maximum security and safety. The Atlantis 200 even opens on both sides for easy access. Catering for a variety of purposes, Atlantis Roof Pods are available in two size options, either long and narrow or short and broad. Atlantis 200: Internal dimensions: 169cm x 76cm, Volume: 440 litres, Weight: 17kg. Atlantis 600: Internal dimensions: 185cm x 55cm, Volume: 340 litres, Weight: 16kg
Pacific 200 Roof Pod
The Pacific 200 Roof Pod is intelligently designed with safety, efficiency and security in mind. With a textured grey finish, the lightweight box uses a fast grip mount system and is positioned lower to reduce air resistance, wind noise and vibrations. Complete with an ergonomic dual-force suspension which acts upwards when opening the cover, and downwards when closing, this convenient Roof Pod can be used for storage on the fly, or to carry luggage on your family holiday. A central locking system enables the key to be removed only if all locking points are properly closed. Internal dimensions: 169cm x 76cm, Volume: 460 litres, Weight: 14kg.
