Hi guys
i thought to start Beauty Fan Club. love the car but hope to buy one .
Share ur ride and collection of Mark-x Info pics etc
The Toyota Mark X (Japanese:???????X??????) is a mid-size automobile created by Toyota for the Japanese market. The Mark X was introduced in 2004 and is manufactured in Kanegasaki, Iwate, Japan. Also sold in China as the Toyota Reiz, it is available with either a 3.0 L or 2.5 L (215PS/212hp) Toyota GR series V6 engine. The engines offer dual VVT-i (variable valve timing) with gasoline direct injection. The rear-wheel drive models have a 6-speed automatic transmission as standard, and the all-wheel drive models have a 5-speed automatic.
The Mark X is the successor to the Toyota Mark II, which was first introduced in 1968. Although the vehicle features an impressive interior with quality that can be categorized as a luxury sedan, it is aimed at the middle market.
Specifications:
Model : 250G
Layout : Front-Engined, RWD
Weight : 1510kg
Engine Model : 4GR-FSE
Engine : DOHC Water Cool V6 24 Valves
Compression Ratio : 12.1
Capacity : 2499 cc
Bore x Stroke : 83x77
Max Power : 158 (kW/rpm) [215hp] / 6400rpm
Torque : 260 Nm / 3800rpm
Suspension (Front / Rear) : Double-Wishbone / Multi Link
Brakes (Front / Rear) : Ventilated Disc Brakes / Disc Brakes
Fuel Tank : 70 Litres
Length : 4730mm
Width : 1775mm
Height : 1445mm
Wheelbase : 2850mm
Tread-Front : 1525mm
Tread-Rear : 1520mm
Min Ground Clearance : 150mm
Standard Rims : 16"
