Body type Sedan
Drive FR
Transmission Electronic control flex lockup attaching4 speed automatic (intelligent) ECT-iE
Displacement, cc 2997
Frame GF-JCG17-BEPXF
Price of new car, thousands yen (Tokyo area) 7000 (~$58300)
SPECIFICATION (SPECS)
EXTERIOR
Exterior dimensions (LxWxH), mm 4560 x 1745 x 1455
Interior dimensions (LxWxH), mm 1950 x 1465 x 1185
Wheel base, mm 2780
Treads (F/R), mm 1475 / 1460
Ground clearance, mm 160
Curb vehicle weight, kg 1560
Gross vehicle weight, kg
Seating capacity, persons 5
Doors number 4
Min.turning radius, m 5.1
Fuel tank capacity, l 70
ENGINE
Engine model 2JZ-GE
Max.power (Net), kw(PS)/rpm 215 ps (158.13 kw) / 5800 rpm
Max.torque(Net), N*m(kg*m)/rpm 30.0 kg*m (294.20 N*m) / 3800 rpm
Power density 7.26
Engine type Water cooling serial 6 cylinder DOHC
Engine information Vertical position
Fuel system EFI (electronic fuel injection)
Turbocharger No
Fuel type Unleaded premium gasoline
LEV system (Low emission vehicle) No
Compression ratio 10.5
Bore, mm 86
Stroke, mm 86
Final gear ratio
Fuel consumption at 10-15 modes, l/100km
Fuel consumption at 60 km/h, l/100km
CHASSIS / TRANSMISSION
Power steering Yes
Tires size, front 195/65r15 91h
Tires size rear 195/65R15 91H
Braking system, front Ventilated disk
Braking system, rear Disk
Suspension system, front Double wishbone type coil spring
Suspension system, rear Double wishbone type coil spring
