Make Toyota
Model Passo 1.0L X
Engine: 1KRFE (Same as VITZ but small changes)
Fuel System Type EFi
Power / Weight Ratio 77,8 HP/ton (58 W/kg)
Power / Engine Displacement Ratio 70,3 HP/litre (52,4 kW/litre)
Transmission Type Automatic (NO CVT)
Throttle BODY Cabled
Brakes ABS with Servo assisted boosterBrakes Servo with ABS
Transmission AT
Throttle Cabled Electronic
AC Passo compressor and filter is different from Vitz
This info is provided in forums and thanx for giving it plz i jux bought a new toyota Passo 2006 1000cc plz can anybody plz be kind enough to tell me about certain details about this car peroidic maintenance like other cars or i should rather straight to Corolla show rooms and make them do the maintenance but plz i want sincere replies because Corolla mechanics are not good at Japnense Assembled cars thats why if any body can plz answer my Following questions:
If i want change all fluids in the oil & lubricants etc where will i get them and what to be used? I m only able to learn about engine oil from posts? wHAT ABOUT transmission oil
After what tme i shud change the Oils?
If there is no service/repair/maintainence manual provided? where will i get it in KHI
What if i want to change my air filters and stuff ???? after what Time i shud change them???
Does anyone know what this 1KRFE means???? in engine type
What is best maintenance shop of PAsso IN ISLAMABAD/ Rawalpindi?
If any of my body parts e.g. head lights , bumpers or fenders get damaged are they really available in KHI or i have to get them imported as well????
PLz PLZ try to help i really need suggestions
Thanking All of you in Anticipation
I ll b really grateful if u ppl will help
