Please suggest gear oil for Toyota passo model 2007 ATF transmission.
Some say its Toyota ATF type 4, some say its ATF GL5.
Can anyone confirm?
Hassan, Toyota Passo before 2010 are 4AT after that all are CVT
Please suggest transmission oil for Passo 2009
Toyota T-IV OR Toyota CVT-F
What Transmission OIL should be used in PASSO 2009
Toyota ATF Type 4 ORToyota CVT F
Can anyone Suggest?
toyota PAsso model 2007-2009 (old shape) have 4AT transmission, and not CVT, so they need toyota T-IV ATF oil
I got my Passo 2007 oil changed from Toyota I-9 Islamabad, they used that oil in the pic above, it was about 2.9 liter.
your 2009 passo is old shape or new one ?
if it has CVT transmission, then CVT oil,if it has 4AT transmission, then T-IV oil
you people can always refer to this fan club,it has a lot of info in it regarding Toyota Passo
https://www.pakwheels.com/forums/wheels-fan-clubs/186490-toyota-passo-daihatsu-boon-owners-fan-club
its old shape like 2007....
BROTHER only use Toyota T-IV in black tin can
Sent from my HTC One X using PW Forums mobile app
Passo 2009 ( OLD SHAPE )I have put Transmission OIL { Toyota ATF TYPE T IV ( Black TIN ) 2.9 L } CLEANED CAMBER & FILTER ....BUT WHEN CAR IS COLD IN MORNING THE GEAR SLIPS .... AFTER Running For a WHILE IT GETS OKANY SUGGESTIONS/// HELP?????BEST Regards
can you plz explain what do you meant by gear slip, as it is auto trans car
Yes ITS Auto Transmission...but its giver a jerk while running & OD light starts blinking This starts happening for a while then when engine/transmission is gets warm to hot this problem endsBut this happens every morning when i start driving or when car is parked for long hours.....
Brother its not transmission its your engine.
Scan it with any good OBD-II scanner.
Maybe your coils are weak.
What have u figure out as I am also facing the similar sort of issue these.
I have same problem with my car did you get any solution.
refer to this Thread please
This topic was automatically closed after 36 hours. New replies are no longer allowed.
