Salam,
I bought toyota passo 2017 Model some days ago. It was running very
smoothly. Owner told me that he was using micking engine oil 5w30 and
its due for change. Today I changed it and used Kendall 5w30 Fully
Synthetic + Liquid Titanium Technology Engine Oil And Also Changed Oil
and Air Filter. Then Filled Peteol From Shell 2000 PKR Normal And 1000
Hi Octane. Suddenly After Some Time I Feel Some Reduced Power In Pick
But Didnt Notice Able So Much. When I Came Home And Put It Into Reverse
Gear The Car Was Not So Much In Power. My Home Garage Parking Is Little
Higher Than Ground And I Always Park Car In Reverse Gear. But Today Car
Was Not Going Up In Reverse Gear As Back Tires Go Up Easily But Car
Stucks When Front Tires Starts Going Up. Then I Tried It On A Jump. Back
Tires Passes Through Jump In Reverse Gear But When Front Tires Try To
Pass The Jump In Reverse Gear, Engine Is Unable To Produce That Power To
Let Them Pass.
What Could Be Reason? Faulty Petrol? Faulty Engine Oil? Faulty Front Suspension? I Am Worrued Please Guide.
