Engine oil myths....JDM's
OIL BASICS
Engine oil claccification:API, IL SAC, ACEA, JASO
OIL SERVICE
Guide to correct engine oil selection
REFERENCE
List of models where only genuine oil can be used
List of CVT models (JDM)
List of DPF-squipped models (JDM)
Guide to Correct Engine Oil Selection
There are many kinds of engines designed for various types of vehicles and driving styles. All have their unique properties, and are tuned for engine oils of a certain range of viscosities. Most of the modern engines built in Japan nowadays require ultra low viscosity oils, such as 0W-20 and 5W-20. Some high rpm NA-engines and most of turbo-charged engines require higher viscosity oils, such as 5W-30 or 10W-30.
However, besides technical characteristics of engines requiring certain viscosities, there are many other factors that influence the engine’s performance, and therefore need to paid attention to when choosing an oil. Some of the basic ones are given below.
●Mileage
What is the mileage of the vehicle? If it is much over 100,000 km, which is a normal thing for a Japanese vehicle operated outside of Japan, the oils of the OEM- recommended viscosities may not be able to maintain proper performance of the engine and provide relevant protection to its aging mechanisms as they used to when the vehicle was new. High mileage becomes a particular issue especially if the vehicle has been in extensive use. What kind of oil can solve the problems of high mileage engines and help extend their life? Generally speaking, high mileage engines need a thicker oil film and extra anti-wear protection. After a vehicle has done 100,000 -120,000 km, we recommend to step up to higher viscosity oils with increased thermal stability and extra cleaning package, or wide range synthetic oils, depending on your budget.
For example, the high mileage alternatives to 0W-20 would be 5W-30 (higher viscosity) and 0W-30 (wider range).
●Service
What is the distance the vehicle travels during a year? How severe is the driving environment? If the travelling distances are long and the vehicle is used in continuous high rpm operations, the engine ages faster and therefore needs a higher level of protection than the standard OEM recommendations can offer. The most effective way of protecting hard working engines, is using fully-synthetic oils with a sturdier oil film, or wider range oils with improved heat resistance characteristics and increased package of anti-wear additives. The standard OEM line-ups usually do not have high endurance synthetic oils and wide-range viscosities such as 0W-30, 5W-40 and 10W-40, that is why Japanese car builders simply offer more frequent oil change (1,500 - 3,000km) with the oils of standard viscosities. In our opinion, a more reasonable way to protect engines in severe service applications is using higher grade synthetic oils or wide range oils, which both can do the same job on standard drain intervals.
For example, the severe service alternatives to Runner 5W-30 would be Pro Runner 5W-30 (higher grade synthetic oil) and Pro Runner 5W-40 (wider range+higher grade synthetic oil).
●Climate
What is the climate the vehicle is operated in?
The oil recommendations for the JDM models that the Japanese car builders offer in the owner's manuals, auto brand websites and oil data books, are based on presumption that the vehicle is operated in the mild climate of Japan. Is your driving environment more severe? The winters are longer and colder or, on the opposite, it is extremely hot all year round? Then you will definitely need an oil of a different viscosity that is capable of protecting the engine at the certain temperature ranges of your driving environment. Generally speaking, cold climates require low viscosity oils as of SAE 0W or 5W grades, while extremely hot climates require high viscosity oils as of SAE 40 or SAE 50 grades. To ensure effective protection of the engine at all temperatures ranges, we recommend using wide range synthetic oils, such as Pro Runner 0W-30, 0W-40, 5W-40 and 5W-50.
●Driving style
Depending on what the driver considers more important, fuel efficiency or high performance, we offer oils of different viscosities that will be appropriate for each particular style of driving. The OEM recommendations focus on minimizing fuel consumption, so if your goal is fuel efficiency, use our Primary Recommendations which correspond to the OEM-recommended viscosities. If you enjoy sporty driving and performance is your number one priority, then you need a high-endurance oil with a sturdy film and superior thermal stability, which can protect the engine in continuous or rapid high rpm operations and improve the vehicle's responsiveness to acceleration.
For example, Pro Runner 0W-30 would be a performance-focused option for the ultra fuel efficient vehicles where 0W-20 is recommended by the OEM.
●Budget
A great number of the JDM models built after 2006 call for 0W-20 rated oils. Manufacturing of any 0W-20 requires use of PAO - an expensive synthetic additive, which raises the cost of oil. For some high performance engines the car builders recommend 5W-40, and a proper 5W-40 is not cheap in Japan either. What to do if the driver's budget cannot afford the OEM-recommended viscosities? Don’t worry - the below chart will offer you several options that will help you choose a price-reasonable replacement, within your budget.
Be careful of Over-spec!
“Over-spec” is using oil of higher specification than the vehicle actually requires, which results in poor performance, increased fuel consumption and often harming of the engine. Some drivers think the more expensive the oil is, or the more advertised it is, the better protection it can deliver to their vehicle, and choose an oil by price or brand name without checking its properties. Such attempts of drivers to choose “the best” oil for their treasured vehicle are understandable, but in fact they do more harm than good and often lead to very sad consequences. It is important to understand what is standard-good, what is better for certain applications, and what is “too good” and absolutely unacceptable. Here are some basic tips which will help avoid trouble caused by the use of Over-spec oils.
! 0W-20 can be used only in the vehicles where it is recommended by the OE Manufacturers, and cannot be used in vehicles calling for 5W-20, 5W-30, 5W-40 or 10W-30 rated oils!
! Avoid using 10W-30, and do not use 10W-40, 15W-40, 5W-50, 10W-50, 15W-50, 20W-50 and 10W-60 in the ultra fuel efficient engines calling for 0W-20!
Application: ◆ultra fuel efficient NA-engines
◆certain types of modern turbo engines with small displacement
Primary Recommendation: ECO RIDER SM 0W-20
Use ECO RIDER SM 0W-20 if:
the vehicle is in good technical condition
the mileage is under 100,000 km
the vehicle is operated in standard driving environment and performance reserve is not necessary
the vehicle is not used for sporty driving or other applications involving continuous high rpm operations, or were increased heat resistance is required
If all the above statements are true for the vehicle and for the driver, and the oil is within the driver’s budget, ECO RIDER SM 0W-20 is just what you need.
Option 1: PRO RUNNER SM 0W-30 - a higher grade option, combining outstanding fuel efficiency with high performance. Excellent choice for performance-focused driving, severe service and high mileage applications
Characteristics:
slightly thicker than 0W-20 → excellent for higher mileage engines, including extra high mileage applications
wider range → excellent for performance-focused driving, severe service and high mileage applications
increased heat-resistance → excellent performance even in continuous high rpm operations and in harsh driving environments
increased cleaning agent and higher TBN → better performance on poor quality fuel
Use Option 1 if:
the owner of the vehicle wants to have a performance reserve, for sporty driving or severe service applications
the vehicle has gone through severe service or poor maintenance, and needs an oil delivering increased anti-wear protection and cleanliness
the mileage is over 100,000 km, and the engine needs a thicker oil film
the vehicle is operated in severe driving environment, and needs a wide range oil with a sturdy oil film and increased anti-wear package
the vehicle is used for sporty driving, and the driver needs a high performance oil delivering better responsiveness to acceleration
Option 2: PRO RUNNER SM 0W-30ECO RIDER SM 5W-20 - an excellent cost performance alternative to 0W-20, recommended for the applications where a thicker “green” oil is required
Characteristics:
slightly thicker than 0W-20 → sometimes more effective than 0W-20 in certain NA-engines, especially the ones with large displacement, and higher mileage ultra fuel efficient engines originally calling for 0W-20
Use Option 2 if:
The application is a full-sized vehicle with a big engine, and although the owner’s manual recommends 0W-20, you feel from the engine’s performance that 0W-20 is too thin for this particular driving environment
The driver prefers to use a fuel efficient “green” oil, but ECO RIDER 0W-20 is beyond the budget
Option 3:
PRO RUNNER SM 5W-30 - use for performance-focused driving, severe service and high mileage applications
RUNNER SM 5W-30 - use for budget-focused driving
Application: ◆heavy vehicles with fuel efficient NA-engines
◆fuel-efficient NA-engines with large displacement
◆fuel efficient NA-engines built in the early 2000’s
Primary Recommendation: ECO RIDER SM 5W-20
Use ECO RIDER SM 5W-20 if:
If all the above statements are true for the vehicle and for the driver, and the oil is within the driver’s budget, ECO RIDER SM 5W-20 is just what you need.
Characteristics:
sturdier oil film → longer service life and more effective anti-wear protection
Use Option 1 if:
Option 2:
RUNNER SM 5W-30 - use for performance-focused driving and high mileage applications
Option 3: PRO RUNNER SM 10W-30 - use for budget-focused driving and high mileage applications
Option 4: PARTNER SL 5W-30 - use for budget-focused driving, additional cleanliness, and high mileage applications
Application: ◆NA-engines
◆high rpm engines
◆turbo engines
Primary Recommendation: RUNNER SM 5W-30
Use RUNNER SM 5W-30 if:
If all the above statements are true for the vehicle and for the driver, and the oil is within the driver’s budget, RUNNER SM 5W-30 is just what you need.
Option 1: PRO RUNNER SM 0W-30 - a higher grade option, combining outstanding fuel efficiency with high performance. Excellent choice for the drivers who seek to improve fuel efficiency while maintaining high performance
Characteristics:
thinner than 5W-30 → better fluidity at low temperatures → increased cold start protection even in extremely cold driving environments
better fuel efficiency, while the overall performance level is higher than with 5W-30
Use Option 1 if:
the owner of the vehicle wants to improve fuel efficiency without compromising the performance level
the owner of the vehicle needs a thinner oil for increased cold start protection
the owner of the vehicle needs a long drain oil for extending service intervals
Option 2: PRO RUNNER 5W-30, 5W-40 - use for performance-focused driving, severe service, longer drain and high mileage applications
Use Option 1 if:
the vehicle is operated in severe driving environment, and needs a wider range oil (5W-40) with a sturdier oil film and increased anti-wear package
Option 3: RUNNER SM 10W-30 - use for budget-focused driving and high mileage applications
Option 4: PARTNER SL 5W-30 - use for budget-focused driving and additional cleanliness
Application: ◆turbo engines
◆high rpm NA-engines
◆older engines of the ’90-s
Primary Recommendation: RUNNER SM 10W-30
Use RUNNER SM 10W-30 if:
If all the above statements are true for the vehicle and for the driver, and the oil is within the driver’s budget, RUNNER SM 10W-30 is just what you need.
Characteristics:
wide range → much better fluidity at low temperatures → increased cold start protection even in extremely cold driving environments
much better fuel efficiency, while the overall performance level is higher than with 10W-30
Use Option 1 if:
Option 2: RUNNER 10W-40 - use for performance-focused driving, severe service, and high mileage engines
Use Option 2 if:
the vehicle is operated in severe driving environment, and needs a wide ranged oil with increased heat resistance characteristics
Option 3: PARTNER SL 10W-40 - use for budget-focused driving, severe service, increased cleanliness, and high mileage engines
Use Option 3 if:
the driver wants to use a 10W-40, but RUNNER SM 10W-40 is beyond the budget
Winter: PRO RUNNER SM 0W-30, 5W-30, 5W-40, RUNNER SM 5W-30, PARTNER SL 5W-30 - choose according to the budget and personal preferences of the driver
Application: ◆high rpm/ high performance engines
Primary Recommendation: PRO RUNNER SM 5W-40 - most recommended for standard driving conditions
Option 1: PRO RUNNER SM 0W-40 - use for maximum performance
Option 2: RUNNER SM 10W-30, 10W-40 - use for economical driving
Application: ◆turbo charged diesel engines
◆NA diesel engines
Primary Recommendation: DIESEL TURBO S CI-4 10W-30 - most recommended for standard driving conditions
Option 1: RUNNER/PARTNER CF 10W-40 - use for performance-focused driving and high mileage applications
Option 2: RUNNER CF 15W-40 - use for performance-focused driving and severe service applications
Winter:
PRO RUNNER CF 0W-30, 5W-30, 5W-40 - use for performance-focused driving
PARTNER CF 5W-30 - use for budget-focused driving
Application: ◆DPF (DPR)-equipped diesel engines
Primary Recommendation: ECO DIESEL 5W-30 DL-1 - most recommended for standard driving conditions
Option 1: DIESEL ENGINE OIL 0W-30 DL-1 - for increased cold start protection and fuel efficiency
