Hi.
So I have a Toyota Passo 2014. The ECO is on by default and it goes away if I press the pedal a bit harder. I wanted to ask, if I disable it will the performance be similar to when it goes away while pressing the pedal hard or it will be better?
so what happens is nothing major, actually you'll see 1 2kmp/l difference if kept off with same driving style. As engine holds gear at a slightly higher rev that is it
@hash4ui guess you can guide better.
above Aizaz response is pretty on point
Thanks for the answer.
