Any codes? You first have to check whether ECU is providing power to fuel pump via scanner. If you got good scanner like Toyota's Techstream, you might be able to manually turn fuel pump on.
If it is turning on via turning key or manually via scanner, then you would be checking continuity between fuel pump and ECU.
