AOA every one. I've Toyota Platz 2003 car. It has no pick on CNG as well as petrol. On motorway its speeds doesn't go above 100 or 110Km/h. Is there any technique to boost up the pick and speed?
As Platz is a JDM Car... I think there is Speed Limiter in it!! Check it if its installed in yr platz
is your platz 1.0l or 1.3l
Asalam O Alikum Hanif,
since how long have u owned the car?
Get the plugs checked.MAF sensor tooAir FilterFuel FilterPlus check for the ATF density and levels.
I suggest u get it checked from a good mechanic.
What is ATF ?
Automatic Transmission Fluid
Pull your Accelerator Pedal Upwards By Your Hand,I think It is Pressed Downward By excessive Use =)
bro first of all these engines are not meant for CNG so u can expect all this.it already got heavy body for those tiny 1.0 engine.
