Do check on the periodic maintainence. Oil change, plugs, Air filter, Oil filter and alignment and balancing of the car.
cat converter is the 2nd step.
Also get the ECU reset and throttle body cleaned.
Than check for milage and opt for good fuel from a reputed pump. if you are in isb go for PSO F8.
