why do you need a key. it is a keyless entry push button start variant. simply keep key in bag or pocket
L is the basic variant. It doesn’t come with push start and smart entry.
if this is the case then nothing can be done.
Yes, L is the most basic variant of Toyota Aqua which doesn't come with push start however it does have Remote Key. But my aqua came with simple key only.
I read somewhere, there are some Remote key makers in Karachi., unable to locate that thread..
Odd thing happened today, when i started my car in the morning the fuel display was half a tank but i remember yesterday there were only 3 bars not 5. When i switch to trip its is calculating the average kms remaining based on the 3 points. What can be done? Is the sensor faulty?
Price?
Mine has Panasonic strada, these systems are for Japanese market only and their language cannot be changed nor there maps. Still I have heard about a person lately who changes the whole software if these systems.
Can you give any cell number or idea where this person can be found.
as I have heard of some CD that can update the map, not sure about the language.
I am working to get hold CD so that at least map is updated. One can read the map with translator
A.O.AGuys my Aqua G is showing 25 Km/l while after adding 32 Liters of petrol (20l High Octane + 12l Normal) it has run for 600 Km. that makes 19 Km/l in Karachi city area. WHat do you say, think this is lesser
@Naweed thats decent milage even without hi-octane you can get 17+
03334701580 ustad mughal.lahore.
03155310935
It's been more than 18 months now, ask I could find are these two numbers.1 st one is in Lahore, and he did change software of a jdm nav entertainment system.Never tried the second number, may be he's from rwp.
Average on meter is a lie.The real average is by filling tank to full and then check km driven.25 km/l average means 900 kms in a tank which seems illogical.My car has driven maximum of 725km in a tank, that excludes the reserve fuel which is not counted in range, so in my opinion aqua can do a maximum of 800 km without air con.So the all season economy is roughly from 17-21 km/l.
P.s. I don't suggest you drive beyond 650 km.
Thanks Dear
I just spoke to Ustad Mughal and he says language cannot be changed. neither do the map can be updated.
But i have reached some place with my navigation that reads copy CD to SD card. Also there are some tablets that need some sort of permission to download data from net. i am stuck finding the Tablets.
While 2nd number is closed.
Thanks Buddy.
Hmm. the car fuel light has started blinking, how much can i drive with this blinking, as think petrol pump will be at least 12 Km from my work place.
Can't remember...it either was 10 or 25 km..or 6 litres of fuel.If you have owner's manual of aqua you can find it there, obviously with help of Google translator.
You will find an option of using map from sd card but you can't use as ,at least my system, can read map from maps.google/jp only, you basically save the map and use it offline. I even emailed Panasonic in Japan and they said the same that it's local model of japan and nothing can be done with it.My system doesn't accept any other sd card than Panasonic..sensitive hain bahut
Yep it is 5 L
(The minimum amount offuel to add to make the low fuel level warning light stop flashing is about 1.3gal. [5.0 L, 1.1 Imp. gal.] when the vehicle is on a level surface. This valuemay vary when the vehicle is on a slope.)
75 km - 100 km then...I will not recommend to drive this much on reserve...get it filled asa you find a pump.
HmmmOK thanks
