[quote="danishmasud, post:5, topic:453295, full:true"]
Thnx bro for ur suggestion. Will try to do it my self but is it safe to drive like this as in city i rarely drivr above 80 km/h and light comes up only at 100 km/h or above and then it vanish when i tur off ignition and start it back again.
Everything else is perfectly fine including mileage, pick,shifting i mean i cant notive any thing in car. Even i just drovr it to 140 km/h and it went all good without any issue or knocking or anything you could say.
In another thread i was reading and OP mentioned that it was due to his one malfunctioned fuel injector. Do you think this could be the reason for it as well.
[/quote]
Now decide yourself. Because my car was also fine before that DIY, no check light, smooth etc. The only problem was that due to blocked cat, unnecessary pressure starts to build which in return damage the main silencer seal after 1 week max. Means seal got leaked everytime due to excessive pressure and that annoying bhurr bhurr sound starts. Rest take advice from other experts also.
Especially from @Xulfiqar & @rajaatta
