Aoa
Anybody guide in this what would be the best coolant for Vitz third gen. Should I go with Toyota super long life or can I try Havoline or any other brand ? JazakAllah
sir @officialmusman Caltex Premix the best
How much litres does it need for flush and to pour it again 4L ? Premix 50/50 or Premix 55/45
sir @officialmusman
Begin by draining the old coolant from the radiator. Ensure that the drain taps are closed securely after draining.
Place a funnel at the radiator inlet to facilitate pouring the new coolant.
Pour two bottles of Caltex premix coolant into the radiator through the funnel.
After adding the coolant, fill the rest of the radiator with distilled water until it reaches the appropriate level.
Start the engine and allow the automatic fan to run for two cycles to help circulate the coolant properly.
While the engine is running, continue to add distilled water to the radiator as needed to purge any trapped air bubbles.
Additionally, check the expansion bottle and add distilled water to it as needed to maintain the proper coolant level.
By following these steps, you'll effectively flush and refill the coolant in your vehicle's cooling system.
Thank you so much. I will follow the same steps while changing it. JazakAllah
