if there are no error codes upon scanner. It is time you shall calculate the fuel consumption using tank top up method.
Fuel avg over cluster is always misleading. specially in city wide traffic drive.
Top up tank reset odo trip meter, note down main odometer reading. & quantity poured.
drive car as usual after half tank or 200 kms, go back to same station same dispenser top up again. note down odometer and trip meter A - reset again drive .
at half tank or 200 km run top up note down qty poured, repeat - 2 more times
that will give you per litre km consumption which may be quiet different then fuel avg display over cluster.
