Hi Team
here is a nightmare of Vitz
Model:2006
OD0: 121000
I got a major problem with the transmission 85000 kms the car got in first gear in middle of road and was not shifting... showed it to Khan autos Faisal he fixed it but told me need a transmission change Cost 55000, but the fix worked but once fixed the Cham Shaft sensor lit up the check light.
On 96000 the transmission stoped responding and car went nuteral. took it to murtaza motors Zamzama (Tahir) told me that the trans isgone need to open and check. he luckily found out that the trans oil pump was at fault and he replaced the same and another part and oil and stuff and charged me 18000 inclusive labor oil and parts.
Now the problem: since past 15 days the car is sinking or choking full accelerator but does not go beyond 75 KMPH and the sound of engine is as RPM is around 6 - 7 alot of pressure but no acceleration.
Took it back to Murtaza motors he suggested change of Trans oil again as the parts changed might have blocked the filter / Jali... so got it done poured Silver Tin can of Toyota CVT - TC oil.
No relief or should say 5 to 10 % improvement but still same....
if the car is neutral the engine is soundless but once we start driving and car gets in motion it generates alot of sound and no pickup , but still the gears are shifting perfectly no issue with that...
please help me out as i am screwed badly...
Here are some suggestions by different mechanics:
- your engine is full of carbon we need to take it down and open and clean all carbon deposits and then the car will be fixed
- The gear oil you have put is not right u need to change it and alsothe engine oil
- you need to flush the engine - then no its a risk as the deposits might might seize the engine
- Today showed it to Jawaid at Cantt Baba motors he said get the Transmission changed completely
Man i am really in big trouble if you can PM me and we can have a talk. we may be able to reach the solution.
Taking the car tomorrow to Toyota Central and Southern to get an assessment for the problem.
i have spent atleast 8000 with no remedy now i doent wan waste more money without any remedy.
I guess when last time i got my engine oil changed the person touched the AIR BREATHER TUBE what is the setting.... when driving it seems jaise engine to saans nahin aa rahi...
Please help me out as i am in big time trouble....
Awaiting reply
Bilal
