-Since its coming fresh on Japanese fuel you wont be needing any fuel system cleaning,
-CVT oil is to be changed at 40,000kms so being safe change it once you have the car, (Use TOYOTA CVT FLUID only)
-Stick to OEM toyota filters, and change them at every oil change, (1kr-fe) doesnt has the conventional steel oil filter, Its a paper filter in this model.
-Im using Caltex Havoline 5-40, Zic is good to. But i like Caltex much better for my cars. A basic Caltex (10-30) is good if you change it on timely intervals.
-Let you get your hands on it, Then decide if it needs work, Other then that keep it as much away as possible from local mechanics. (dont even change the plugs if you dont feel like doing so).
-Since youll get it offloaded in front of you, Chances are service booklet or last maintainence stickers would be present either on pillars, or under the bonnet, near engine or somewhere maybe.
-The Japanese link i shared only 2 models being produced in 2010,
- I wish you get the most options with your car
im not sure if F limited comes with Push start or U comes with push start
