See details under U grade:
Sorry, I could not paste the table properly; below might be confusing.
Grade CVT Manual Transmission
U X F B RS
1.3L 1.5L 1.3L 1.0L 1.0L 1.5L
Powertrain 2WD (FF)
Length(mm) 3,750 3,800
Width(mm) 1,695
Height(mm) 1,520
Wheelbase(mm) 2,460
Track Front(mm) 1,470 1,480 1,460
Rear(mm) 1,460 1,470 1,450
Minimum turning radius(m) 4.7 4.4 5.5
Ground clearance(mm) 145
Curb weight(kg) 1,030 1,050 1,010 980 1,060 1,030
E
n
g
i
n
e Model 2SZ-FE 1NZ-FE 2SZ-FE 1KR-FE 1NZ-FE
Engine type In-line 4-cylinder DOHC In-line 3-cylinder DOHC In-line 4-cylinder DOHC
Displacement(cc) 1296 1496 1296 996 1496
Bore x stroke(mm) 72.0 x 79.6 75.0 x 84.7 72.0 x 79.6 71.0 x 83.9 75.0 x 84.7
Compression ratio 11.0 10.5 11.0 10.5 10.5
Maximum output 64 (87) / 6,000 81 (110) / 6,000 64 (87) / 6,000 52 (71) / 6,000 81 (110) / 6,000
Maximum torque 116 (11.8) / 4,000 141 (14.4) / 4,400 116 (11.8) / 4,000 94 (9.6) / 3,600 141 (14.4) / 4,400
Fuel consumption(km/l) 19.6 18.6 21.5 22.0 18.6 17.6
Major measures to improve fuel efficiency Continuously variable valve timing mechanism, electric power steering system, charge control, Super CVT-i, torque converter with a lock-up function and (for vehicles with āIntelligent Packageā) Idling Stop System Continuously variable valve timing mechanism, electric power steering system and charge control
Fuel supply system EFI (Electronic fuel injection)
Fuel capacity (l) 42
Steering Rack and pinion
Suspension front
MacPherson strutted-type coil springs
rear Torsion beam type with coil springs
Brakes front
14 inch Ventilated disc 15 inch Ventilated disc
rear Leading / trailing 15 inch Disc
