just ask urself why and how a 2011 model will need paint job for a fresh look as its not a very old model.
To be honest...minor dents and scratches are routine in pk when driver is careless. Other wise with a sensible driver u don't get lot of scratches which requires shower..also when u will sell then how next buyer will believe u...But most important thing is every thing has a price..so if price is like 13 to 14 lac with shower then ok otherwise think again
Salam I have an issue that after battery replacement my vitz 2013 reverse camera and radio has stopped working and showing some Japanese language what to do ?
Its a safety features. Your lcd gets locked once battery is removed or power is removed from the LCD by any method. You have to enter an unlock code for the LCD to work again.
Please send an image i'll send you the unlock code.
Hi! I am selling full rear tube of vitz 2006 2nd generation complete brakes handbrake cables drums hubs etc. Speedo meter OEM head unit and front brake calipers both. If interested inbox me love to give it to my fellow vitz club member.
does speedometer is with rpm meter as well?
No I changed mine with rpm one this is mine original one
ok, I also need with an rpm meter, can you tell me how much was it?
That will be mistake because resurface is not an ordinary job if done with mproper machine and expertise it will add vibration and finally have to replace the discs. So just sandpaper it and clean with brake cleaner liquid and if severely lined than change them for peace of mind. I would do it like this for my car. Rest is upto you Brother. Good luck.
7500rupees and the front plastic was scratched and b and s gear indicators on meter are not working checked three this was the best of the lesser evil..
what about the other light indicators like airbag light, its position is different in meters with rpm, do they all work when turning on the ignition?
All are working and finely placed. But colours are not good mostly orange light one is available in the market whole meter light background talking about must have seen on YouTube also
AOA. At what mileage should I change the trans fluid in 2014-2019 toyota Vitz with a cvt,,,currently it is Driven 75000 km..Waiting for your kind responce.THANKS
and should i go for toyota dealer for gear oil change or any other recommendation from your side i am from Hyderabad Sindh and Karachi
W.S. Brother I am of the opinion that CVTF in case of Vitz, may be flushed after every 40-60,000 Kms.
At max. 60, not more than that.
I think CVTF has never been changed in your case. Get it replaced with Toyota CVTF-FE ASAP.
60k initially and then after every 40k
reference for this?
Dear friendsI have my vitz 2010I have noticed oil seepage I have marked in the picture. Can you please tell what is an actual issue and how to solve?
any one please
This looks like gear oil seepage. Have you recently changed gear oil?
