Any good and reliable place to get vitz 2015 cvt fliud changed in karachi?Also can i pour in caltex cvtf fluid instead of toyota cvt fe?
Yes. You can pour Caltex Genuine CVTF, instead of Toyota CVTF TC or FE.
Caltex CVTF meets / exceeds these both criteria.
Tomorrow I will be going to replace head assembly of my Toyota Vitz 2013 Japan model 1KrFe. All I want to say shall I keep my original head assembly with me or exchange with new one and pay the price difference and mainly what oil grade shall I pour as it will also be used condition stuff. About an year before I had a compression test which was I think quiet satisfactory but car give blue smoke on heavy foot after I make it run around 15k. Right now I am using 10w40 after using 2 time 20w-50 with change interval of 2k but now I already make a mind to replace head assembly as Silencor tail is getting black day after day due to oil burning also also have to check oil level after any trip.
If the engine is fine, use 0w20.
Get some expert with you to buy the new assembly.
Or
Get your engine overhauled from a good shop, that will be the best option with guaranteed reliability..and can use 0w20.
A.o.A pakwheelers my vitz 2000 is behaving strange. My vitz right indicator was not working and one fuse was blown yesterday i took my car to workshop the electrician changed the blown fuse and also fix the indicator and told me that it was due to bad ground of back right indicator. But after solving my indicator problem my transmission indicator flashes and as soon as i turn off the right indicator the transmission indicator stops flashing. I have checkes my transmission fluid it is up to the mark. Plz help me in solving this issue. I am also attaching the link of the video of the problem check it out guys. https://m.youtube.com/watch?v=VHax_usiOFg
Dear SeniorsMy vitz 2010/2013 drive is very sluggish even it doesn't move without accelerator. I don't know why she is getting weird. I have tuned the car around 4 to 5 months ago with replacing of air filter and throttle body clean. It is almost 1000 km I have replaced Spark plugs. Can u please advise the solution.Thanks
Dear colleagues. My vitz 2013 model driver side mirror indicator got damaged. From where I can get it new in Islamabad or Rawalpindi
Yesterday head assembly replacement work got done. All I need to know on what stage shall I change first oil I pour (how many kilometre). Also what are the tips member suggest me to follow to inspect engine performance. As presently it’s behaving very normal. No abnormal vibration on D mode while feet on brake also pick is also good. Last, what may I suppose to do with original head assembly as i still have.
@muddaser_pervaizDid you read my viTz issue above...Do you have any idea how to solve it.
Plz guide me how to solve this issue.
How to solve transmission indicator problem. It flashes when right signal indicator is tuned on and back to normal as soon as the right signal is turned off
Frm blinking D u means transmission indicator, or the red one indicator on left which is air bag indicator. If D then u need to scan fr error as thr is some short circuit, loose connection etc.
Yes D is blinking and it all started after fixing right indicator tail light. And the electrician also said that there was problem in ground connection of right indicator.
Well dear can’t say confirm all I thing it need to check by quality technician sort of scanning. Where you locate ?
Then check all wiring near gear lever.
Alhamdullilah my problem got solved within 10 mintues. Today morning i went to electrician and showed him the blinking D with Right signal indicator and it was due to the loose wires of side fender indicator bulb. The wires were completly loose even one wire just comes out as soon as the electrician touched it. And then to avoid any other similar issues the electrician also cleaned most of the ground wires and connected an extra ground wire to the effected tail light right indicator.
Someone say to pour fuel injector cleaner in empty tank and refill it. it will enhance the engine performance and sluggishness, idle vibration will go away. But one thing, the cleaner will effect the rubber hose and seals??? One of my friend told me to clean CAT.
sluggishness will go away only if you switch to the company recommended oil grade.
